Hi, wondered if I could get some advice.
I've changed an old Proscon mechanical room stat as it was on the blink (needed the dial wiggling round to make the rads get hot) for a Drayton RTS8 a la Screwfix.
It's a Baxi back boiler and the wiring to the stat is a flat twin and earth with 240V across the live and neutral and a separate red wire which I think is the demand wire from the boiler.
Connecting it up in 3-wire configuration as per the instructions doesn't work. Everything looks ok but the boiler comes on then goes off again.
So I'm back to wiggling the Proscon dial......
Any suggestions most welcome.
