hi all sorts.
I have and idea for you.
You will need for this:
[1] a piece of plywood, 1/2" will do. Dimensions of which will contain
a sample of your rocking horse rocker. i.e 1500mm x 500mm.
Perhaps you have an existing rocker handy?
[2] jig saw. "Clue is in the name"
[3] Router, does your new router come with a guide bush?
normally a good make will supply a 30mm guide bush with accessories.
[4] Two G clamps.
Now for the fun part.
[a] Trace the sample onto the ply wood. Be very very careful here,
because what ever line you draw, you will cut, you will route out,
you will have as a finished product.
Copy a parallel line to the one you have just drawn.
Now for the tricky bit!
I will assume you have conmen sense and "some" carpentry skills,
over the last 10 years. So:-
Depending on how wide you want the rocker to be, will determine
how far apart you draw the second line. You have to take into
account the size of the cutter, and the 30mm guide bush on your
new router.
Perhaps experiment a little on other boards first until you get it
perfect.
[c] When you are 100% happy with your pencil lines, cut out the shape
with you jig saw. Here, you will have to be meticulous. Even the
slightest out of line cut will mean that every rocker you rout out will
have that misshape.
[c] What you are aiming for is a board with a hole in it, the shape, and
size you want. So that when you place this board, which is now your
very own bespoke jig.
[d] When you are happy with the result, you are ready to start making
as many rockers as you want, fast, with identical reproduction.
[e] Place your jig over a new piece of plywood, clamp it down with the
G clamps, and rout away.
Make sure the bottom board is secure too, because you will have
run the router along the edge of you jig. If the ply you are routing
is very thick, then just take shallow cuts between plunges. If too deep
the cutter will bite into the ply and spoil your shape.
It might be a good idea to run you router in the same direction as the
motor turns, to avoid the router from biting and drifting into your
shape.
I have a feeling this is what your Uncle Tom was going to explain to you.
My condolences. R.I.P
Have fun.
