Well thank you for your help its much appreciated. On the off chance i don't suppose you'd know how i'd be breaking the law, as one of the previous posters has indicted, in doing this. If like i said it will all be certified.
You can certify compliance with part P of the building regulations and have electrical work notified to your LABC in a couple of ways.
The easiest of those is to use an electrician who is a member of a self certification scheme, who will carry out the work, inspect/test, and submit the necessary documents to the LABC via his scheme provider. An electrician may only submit work through the scheme that he has carried out - he is not allowed to certify the work of householders, and as a minimum risks losing his scheme membership if he is found to be doing this.
Alternatively, anyone may legally carry out notifiable electrical work if they inform their LABC before starting the work, and pay the necessary fees. What should then happen is that you will be given permission to start the work, the work will be inspected after first fix and, if compliant, allowed to continue onto second fix. Building control will then send round an electrician to inspect and test, fill out the necessary EICs, and provide you with a completion certificate.
Sadly, each LABC has their own ideas about how this should work, with many choosing to ignore the approved documents. As a result, you could give £200 or so to your BCO, and they will then expect you to employ an electrician to perform the necessary tests on their behalf, at your expense.
If existing work is being carried out under a building notice then you may not be too late to inform building control of your intentions to carry out notifiable electrical work, but you would have to ascertain their requirements. Chances are they will want to see an EIC as a minimum.
