Hi folks, thinking about running power out to my shed and was wondering what would be the best thing to do?.
I was going to spur off a socket on the downstairs ring. Then run a cable out the back of the house buried under the ground to the shed.
Would probably be 2.5mm armoured cable. However I think i might need over 10M and it aint the cheapest.
Then Into the shed I was going to put a FCU then run to a double socket. I was wanting a light in there too though?. Would it be possible to run a 2.5mm cable from the double socket to another FCU with a 3A or 5A fuse then 1mm to a light?.
The downstairs ring is protected by a 32A rcbo. There is 7 double sockets on the downstair ring. So if I spur from this would be 8 double sockets and a light.
I was wondering, I have some spare 2.5mm twin and earth. It would be enough to run to the shed. I also have a load of metal conduit from the lighting circuit.(old 1950s property) Would it be possible to run the 2.5mm twin and earth in the metal conduit buried under the ground?.
Nothing major would be plugged in at the shed. Some led lighting and perhaps a radio.
Any advice would be much appreciated.
