I want to run some SWA to power my log cabin, just lights and 1 double socket. What thickness SWA should I use for a 50m run? Also, can I mount it on my fence instead of burying it, as it will be a huge trench to dig. The fence is wooden panels set between concrete posts and very study. If I absolutely have to bury the SWA, would you recommend I use conduit, say 25mm Polyethylene blue pipe?
I was planning to run the cable straight from my CU on a spare 16A MCB and terminate it in the cabin with a MK IP65 Garage Unit (40A 30mA RCD+1x6A 1x16A SP MCB). Would this work? More to the point would it pass Part P regs?
Finally, I have a shed behind the cabin that I want to power too, just lights + 1 double socket. Will I need another garage unit for this or I can I somehow piggyback off the log cabin unit? If so, how?
Thanks for your help, much appreciated!
