- Joined
- 27 Jan 2008
- Messages
- 23,861
- Reaction score
- 2,699
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
In spite of having a glass between the quartz envelope and the user, to stop UV light and to also stop hot bits of quartz if it shatters from falling on the carpet, the size of the quartz is such that it takes longer to cool than any parts of a old type tungsten lamp, so with a table lamp or standard lamp if they fall over even after the bulb has broken and extinguished it still has very hot parts, and where the quartz envelope is inside a glass envelope the breaking of the glass outer will not cause the filament to rupture and lamp extinguish.
The death of Jake Jackson report does not state if the outer glass broke or not, however two years ago we went to look for new chandelier pair for living room, I was surprised to see fittings with G9 quartz bulbs with no glass globe to contain any hot bits should the bulb shatter.
The problem is LED bulbs will fit the same chandelier so nothing wrong with the fitting, just putting quartz bulbs in the fitting, same with this type
nothing wrong with the bulb, however fitting it in a table or standard lamp if it gets knocked over the outer glass can smash allowing 250°C quartz to touch the shade, and the shades were made for old type bulbs.
