hi. i have just moved into a new build build home from taylor wimpy. three bathrooms and has an ideal logic 35kw combi in the kitchen. under the kitchen sink there is a coleffi 3 bar valve after the stopcock. it has an adjuster on it which varies from - to + and is currently set on '-'
there is no gauge anywhere to be seen.
the issue is, when the electric shower is running (10.5kw on 10mm electrical wiring), if any other tap is opened even slightly, the shower gets low flow and stops heating.
ive measured the cold flow in the kitchen sink and im getting 7 litres per min.
i have 2 questions really.
can the valve be adjusted to stop the issues im having?
also, can an inline pump like the salamander home boost be fitted within this configuration?
NB i assume the pipework coming into the property is 25mm and reduces to 15mm, although i havent actually checked this.
