Salus RT520RF
5 Nov 2023
Hi all, I had a new boiler put in a couple of months ago and have the Salus RT520RF controls, as its getting chilly now I've set it for the heating to come on...
my issue is the radiators are hot when they should be off... I've set it at 10 for the off time but they are boiling.
I've re-paired them and checked the timings several times to no avail...
any ideas/suggestions would be great!
Thanks in advance
Just had a thought and checked... my rads are the same temperature as the water... going to decrease the rads and see if it works.. fingers crossed
Does the boiler fire up constantly? Sounds like the link could have been left in - get the installer back.
Thanks for the quick reply, and no, not to my knowledge... when it's in summer mode it's fine... I turned the heat setting down on the boiler for the rads and they cooled right down... but I think I might have lowered it too much, they should be on now.
I have a Valient boiler if that helps?
  • Thanks
Reactions: CBW
As CBW above at 2 months old get installers back.
Just one though like most stats of this type it switches both time and temperature.
What back set temperature have you set at off times?
Hi, the temperature is set to 10 at off time
The red link is for a 24v thermostat, so in summer mode the boiler will not look for a call from the room thermostat, as soon as you select heating, with the red link in the boiler thinks there is a constant call for heat, it has to be removed
Thank you all very much for your imput, I'll get onto the company that installed it, it's all a bit confusing to be honest, in my previous house the my
boiler was 20+ years old and worked like a dream, they certainly don't make em that way anymore!
Agree with you, but to be honest any boiler is only as good as the person who installed it, not the boilers fault the installer you used cant read the installation instructions and install it correctly, do not pay any additional fees for getting them to come back and do their job correctly
