Sanding a door prior to painting
1 Dec 2011
Middlesex
Hello,
I have been wet sanding for an hour and a half an internal door and it's frame. I could have saved myself a bit of time when I realised I was also using the wrong side of the paper. It's a very tough old gloss paint and still is a bit shiny. Will that do or does it need to go completely matt? Does every nook and cranny needs to be 100% sanded down?
Also, will I still need to sand down between coats? I will be applying a Primer & Undercoat and a White Satin paint, both water based.
There are other doors to paint and sanding seems to take forever.
Many thanks.
Perhaps they're using wet or dry paper? And the wrong side of that...
I'm using Wet and Dry sandpaper. I dip the sandpaper in a bucket prior to sanding, as per the instructions. I'm using this method as it doesn't create any dust.
Take the door off and work outside?
Use normal 120g paper and key surface that is good and work harder on areas with defects such as dry drips and over coated areas.
Will I still need to sand between 2 coats if I'm using water based paints, or does that mainly apply for oil paints?
Thanks again.
What do the instructions on the tin say? I wouldn't unless there are runs and drips to deal with
Depends on if the job picks up dust.
Run you hand over job after dry, de-nib, if smooth then just apply further coat.
