Sealy 1.5 HP 24L air compressor leaking
25 Nov 2005
Sealy 1.5 HP 24L air compressor does not build pressure. when it stars, build pressure slowly to 2 bar and that where it stays no matter how long I keep it running. and when I switch off it leaks from under the switch assembly (black box). I dismantled the switch assembly and can not see anything that shows me where the leak is. there is a black rubber diaphragm which is in good shape.
yes but still can not work out what is the problem
Press the play button on The YouTube video above.
From about the 5min point to the end it highlights a few areas for you to consider that match the symptoms you highlighted.
He says to drain it once a day or at least once a week. I do mine every 6-12 months. :rolleyes:
Surprised you're not running on compressed water!
I only drain it when I start getting condensation on my hand when using the impact gun!
