What type of contact ?
Flush or surface mounted.
Take contact off door and tape magnet onto contact.This will allow you to set the alarm,but when you enter you could set the alarm off as you have bye passed the front door contact by tapeing together
They are flush, one as got to be removed from the door frame and will have to be surface mounted once new door fitted just need to remove from system while new door fitted
Remove contact out of frame
Take photo of contact
Disconnect contact and remove cable
Re connect contact and tape together
Get new surface contact and fit on new door
Silver screws on contact are the alarm circuit
Gold screw tamper circuit
Make sure gap between contact and magnet is not too big
