Setting out floor tiles to follow base units
27 Sep 2006
Manchester
What is the best way of setting out floor tiles to follow the line base units will be in the kitchen. Kitchen is currently empty having done all the prep of replacing floorboards etc.
I want the grout line to follow a 4m wall run of base units rather than follow the walls (which aren't particularly staight!)
Wondering if there are any tips for this.
Richard
i would go for half a tile showing
if you go for the grout line you will have no adjustment without it showing
Sorry, I should have explained it better, I plan to have about 1/2 tile showing from the plinth, but wonder if there are any tips to ensure the there isn't more tile showing at one end of the room than the other, ie so the grout line is pararell to the base units
Normal practice is to mark the central “x”-“y” axis between opposing/adjacent unit plinths & work back from there but the units must be fitted so the plinths are square & parallel using the worktops to take out any wall discrepancies with the wall; this will generally be far less noticeable. You should also take account of any “problem areas” where there may be discrepancies so they are not in immediate noticeable “line of sight” as you enter the room; usually the wall opposite the door has to be perfect.
There is "standard practice" but there are no hard & fast rules about how you achieve the best tile layout & doing so sometimes means completely ignoring it. It varies depending on the kitchen & unit configuration. Have you got a single run, L shape or U?
