I am looking for some help and advice please.
I am a single working mum of two with little DIY experience.
I have recently had a small log cabin build in my garden, I am now looking at getting power to it. I have had three electricians around to quote for the work.
They where all given the same verbal brief but the specs they have come back with appear completely different so unsure which is best.
The only similarities between the quotes appear to be:
Fit 3, 4ft Led battens.
Fit 6 double sockets
Test and certification
Electrician 1
Install new 60A switch fuse
Run 18m, 10mm 6943X, relay paving and make good grass
Install new 2 way CU in shed
Electrician 2
Install new 80A fused switch
Lay, 10mm armoured cable, customer to sort garden
Install earthing rod.
Electrician 3
Feed shed via 6mm twin and earth. Cable run via conduit attached to garden wall
I am a amatuer wood turner, I will have a small lathe, bench sander and a pillar drill in the shed.
Not sure if it makes a difference but I live in Elgin, Moray
Thank you
Steph
Electrician 1
Electrician 2
Electrician 3
Thank you
Steph
