in the summer I removed a rad and had a bit of trouble bleeding the radiators I may have been a bit impatient .Anyway it all seemed to work ok
now In the morning on the timer the boiler clicks on and starts and I get trickling noises coming from around the storagetank/ pump area and top radiator closest to the storage tank .The boiler turns itself off ( I aassume there is no water for it to heat ) the trickling continues and the boiler restarts and everything works absoluteley ok .the noise stops the water heats up and the heating is lovely and hot
The trickling sound is worrying me It can take 10 minutes for the boiler to start again and thats a lot of trickling .should I bleed the top rad closest to the storage tank as a precaution .Obviously I am reluctant to fiddle about with the heating at the moment as its so cold
thanks inadvance
thanks inadvance
