Hi, new member but long time lurker...
In the middle of having a new combi boiler fitted. Should have been finished by now.
I was just wondering if the condense pipe should fall at an angle to aid flow?
The small pipe on my boiler comes out and down vertically for a 6", then right angle for 6", then down vertical for 6" and then right angle through internal wall to sink waste pipe via a tee insert. No slanted angles at all.
The sink waste, which I put in, is at an angle to aid drainage, but the condense pipe meets it at a slightly upwards angle due to the installer miscalculating the position of the tee insert.
Surely the condensate will not drain away properly and may even back up if the pipe was to even slightly freeze. The system is in an outhouse, so gets very cold, sometimes barely above outside temp.
[/i]
[/i]
