Hello everyone!!
I just need some advice on this one!!!
I'm replacing my old shower with a new one. I was wondering will it be o.k. to use a Flexi pipe compression to connect to the inlet valve on the shower from the cold water pipe. the dimension of the cable is 15 x 15 by 300mm. the reason why i want to do this is that the space in the show is very tight, and I thought this idea was a much simpler job to do, otherwise i will need to buy some pipeing and do loads of cutting etc etc.
i think the only problem with this is that the bore itself is quite small in diamerter so it might restrict the water flow??
any help would be much appreciated.
Glyn
Glyn
