I have a water pump underneath the bathtub which kicks in whenever I open the hot water faucet for shower. The issue is that if I keep the showerhead in the holder at top (so it hangs there and I don't have to hold the shower head) it does not start. I have to take the showerhead out and lower it a bit towards the ground, the pump kicks in. Once the pump has started, then I can put it back at the top and it stays fine. Its just when starting the hot water I need to do the above mentioned process.
It is a bit of a nuisance doing it everytime. It would help me a lot if you can tell me if this issue can be solved easily or would I need professional help and how do I go about doing it.
Thanks in advance
Thanks in advance
