But in this case I think there is a problem with the location of the switch. There are all sorts of rules and regulations in all sorts of areas which are of the form "XYZ is not mandated, but if you choose to implement XYZ it must conform with ABC". In other words, you don't have to have a {something} which conforms with {whatever}, but if you choose to have a {something} it must conform with {whatever}. e.g. (unless I'm out of date), front foglights on cars. Not mandatory, but if fitted there are C&U regulations with which they must comply.To the OP,
there is no specific regulation to have the shower switch inside the bathroom next to the shower. The modern trend is to move them outside the bathroom, or to place them out of site if there is an airing cupboard next door.
If it works for the user and there is no specific reason why the switch should be moved, it doesn't need to be moved.
NICEIC guidance is irrelevant. Only one word for someone who thinks that. Simple!
Sorry to burst your NIC bubble, but two things here:
1. In your own words, you said "NICEIC guidance". It is just that.
2. There are many people who ignore "NICEIC guidance", preferring to use BS 7671.
Hi can anybody guide me to the regs regarding the shower isolation switch siting?
I am helping my neighbour do his bathroom and he has an electric shower which he is replacing with another electric shower. I noticed he does not have a pull cord switch etc anywhere near the bathroom so I asked him about it and he said he has a switch downstairs under the stairs and they are used to it as it has been like that for years.
I am not sure that is satisfactory and whether it needs to be changed to meet current regs if he is only replacing the existing shower with like for like (both 9.5kw) in fact I could not find a definite reg about it only things like the isolation point has to be accessible which I suppose it is.
Is there a regulation regarding where this switch should be located, ie maximum meters from shower, that also states there has to be one?
Seems funny to me them switching a switch downstairs under the stairs then going up to use the shower upstairs etc etc but is there anything wrong with that layout and does he need to alter the installation to meet current regs if he is just replacing the shower unit?
Any help appreciated.
It's not satisfactory and it does need to be changed and there are applicable regs. But would quoting them do any good? Would he take any notice whatsoever?
yes they would I would persuade him, can you give me a link or tell me the reg in the IEE regs so I can look it up please
If it's so simple, why do different people have different ideas?
I can't add anything to what I've already said - IMO an isolation switch for the shower is appropriate, IYO it's not.
IMO under the stairs on the floor below is not a "suitable" location, IYO it is.
