I was looking to fit a shower tray with a riser kit, does anyone have any experience with them?
I'm installing a 900x900mm quadrant 40mm 30 kg stone tray, but there is a water pipe on the floor where the shower should go, so it needs to be raised.
It would be much more sturdy to go down the route of using a marine plywood base on top of 47mmx100mm secured with mortar, but the riser kit seems like a more simple solution.
The riser kit would have the benefit of being able to easily inspect for leaks, and correct them. If it's secured by wood, marine plywood & mortar it would be a much more difficult to correct potential problems.
Was thinking of using one of the following products:
https://www.amazon.co.uk/d/c7h/MX-Group-5017706774109-Panel-Riser-Quadrant-Offset/B007NIW1ZE
http://www.ebay.co.uk/itm/Riser-Kit-plinth-leg-for-quadrant-shower-enclosure-tray-W-/300763322635
Anyone used them before that can recommend a decent one?
