hi,
I am in process of installing a built on in shower valve which has 3/4bsp inlets and outlets. The built in shower head I have needs a 1/2bsp wall plate. Can someone advise where it is better to reduce the pipe.
Is it better to use a 3/4 to 15mm reducer directly at the valve the use a 15mm X 1/2 wall plate,
an inline solder reduction 22mm to 15mm then 15mm to 1/2 plate or
is there a 22mm to 1/2bsp wall plate available.
Your help would be appreciated.
