I have had the usual E15 leak code show and after investigating by looking at bottom of washer after removing lower front panel I can see water dripping from the seal between the steel and plastic filter and pump housing.
Can I buy a replacement seal and is it easy to replace?
The machine is about 10 years old but has been working well and is quite clean, tempted to replace it but noticed that Siemens and Bosch dishwashers are not being manufactured fast enough and in short supply right now.
