- Joined
- 17 May 2012
- Messages
- 10,789
- Reaction score
- 852
- Country
Hi
I need to create a cheap shelter for bbq, bikes etc. Does not need to be 100% water tight, just keep most of the direct rain off.
On the side of my house I have a dead-end path that is about 85cm wide. Single story extension to the left and fence to the right. Path is with paving stones.
My plan:
Fix some wooded supports, or one or two long support, to the side of the house just below the soffit. Fix another horizontal support to the fence posts (or the support running horizonally) near the top. Then built a simple roof with plastic corrugated sheet on a wooden frame that can then be attached to the two supports. a 1 metre wide roof will sit in there nicely with a good angle for draining water off away from the house.
Now, my drill struggles to go into brick. For hanging shelves in the garage I drilled into mortar and plugged that. Seems pretty solid. Can I do this for my shelter, or should I go into brick?
When my gate was put on it did go into the brick, but a gate I guess needs to be more secure than a static frame?
Any other considerations?
Looking at the cheap treated wooden posts - http://www.diy.com/nav/build/timber...ber-L-3000-x-W-75-x-T-47mm-9275868?icamp=recs - and PVC Corrugated Roofing Sheet 77/20 EAN: 5012032085042 from B&Q
I know there are many better options, but budget is really very very tight and I need to get this done as cheap as possible.
My plan:
