12 years ago I built an alcove-type shower installation(tiled brick pillars each end, stone resin tray) with a 1200mm sliding door. Not sure which brand. Still works fine but the bottom of the frame is starting to corrode and the seals are discoloured.
I'm planning to replace it and I want top quality. Not sure whether to use another slider or a bi/trifold. Coram Premier looks good in the brochures, roller bearing runners and frameless glass.
What are your views on sliding versus folding? Obstacles won't allow a pivot door. How good is Coram Premier?
Thanks in advance for any advice you can give.
