- Joined
- 7 Dec 2019
- Messages
- 35
- Reaction score
- 0
- Country
I've just been in the loft to put something in there and while up, I noticed between two rafters light condensation, along with some across the ridge of the roof, between the rafters. No where else seemed affected. Other times I have been up there has been nothing, although this tends to be in Spring and Autumn.
It was difficult to tell by eye if it was water or simply the torch reflecting off the material however upon touching it, it felt wet.
To me, what is odd, is that it is only affecting one part of the roof and not the others, and only on one side. Is this something to be overly concerned about or simply the roof doing its job? There was no sign of mould either.
The humidity in the hall is usually around 55%. We have a fan from the bathroom passing through the loft to an external wall, however, this seems to be working ok. The loft had extra insulation added a prior to us buying it so I believe it's double insulated. When I went up the house was around 20c and outside maybe 0c.
Jim
Jim
