I have used Energenie MiHome smart light switches which don't need a neutral.
Started with 1 some 4 - 5 years ago and it worked well, used as no two way switching in bedrooms, expanded to 5 around 2 - 3 years ago, and found problems used with some LED bulbs, the E27, BA22d, and E14 all seemed OK, but the G9 caused a lot of problems, and had to swap GU10 until found 3 that worked OK.
The G9 flashed when off cured by using a load capacitor
![load-capacitor.jpg load-capacitor.jpg](https://cdn.diynot.com/data/attachments/257/257183-29284278c53abf3eb06fa75e2ce2cd13.jpg)
but also a shimmer when on, swapping one bulb to a tungsten stopped shimmer, but in the end did find a bulb that worked,
![G9-comp.jpg G9-comp.jpg](https://cdn.diynot.com/data/attachments/257/257184-15b21bafe4d3f2c0f6537b82ff5048e4.jpg)
the smaller bulb had shimmer, had one of the larger ones fail, so opened to have a look, found fault, but also could see why no shimmer, there was a smoothing capacitor inside the bulb nearly as big as the whole of the smaller bulb.
The shimmer is clearly a reaction between the switch and bulb, however that is not the end of the story.
I started to have problems with lights not turning on or not turning off, switch off supply (reboot) and it did work again, also had one turned itself into a flasher unit, so now only 2 of the 5 still in service. Also had one smart socket go faulty.
To remove a smart switch or smart socket I need to go outside, down a set of steps and into what is now a flat, it was originally a garage to switch off power, but to remove a smart bulb or plug in smart device I can do it local to the device. So today prefer plug in devices, had one smart bulb fail (GU10 colour changing) but in the main they seem to work well, needed to reboot the zigbee hub once, but the energenie hub lost count how many times.
Whole idea of smart devices is to make it easier, the two remaining lights switches both have remote controls so very handy to switch on/off from the bed. The landing light bulb not so handy as needs the smartlife app to boot up first with phone, intend to replace with a relay, the bottom of stairs switch is not easy to reach, so that light is on a simple timed on/off. Outside light again timed on/off.
We have auxiliary display cabinet lights on a smart extension lead, (energenie) which like the light switches uses a remote control as well as phone. We have one zigbee remote control, and really the phone is a pain as so often mobile phone not to hand, remote controls far better.
Some of the zigbee show on/off, except for the energy monitor the energenie do not show state, so if used to power for example the AC unit, one has no idea if it has actually switched on.
I do like the automation, but the Nest Mini acted like a mischievous little boy, playing BBC radio 4 we would say hey google turn off, get reply turning off 5 switches and all lights when out, command hey google turn the lights back on, got I don't know how to do that yet, so took lights and central heating off google Nest Mini control.
Son seems to have had better results with Alexa, but maybe he is just better at programming it, and Grand Children thought it was funny telling Nest Mini to do something after they had left.
We have no FM radio here so the Nest Mini does work well. However one does need to be careful what one allows it to control.
