Smart Thermostat
10 Nov 2019
Hi, I've bought thermostat that either doesn't have or I can't find a wiring diagram, it looks straightforward but it's not something I'm familiar with. Any help would be much appreciated. It's a Moes bht-002-gclw.
My current timer/programmer is a Hortsmann Channel Plus H17XL:
Left to right wires are earth, N, L, then numbered 1-6, black wire is in number 4.
Red wire connects L to 5.
This is the wiring diagram from current programmer if it's useful.
New thermostat:
I don't know which wire goes in 1 as 2 compared with the old box. Any help/explanation would be great.
Thanks.
Neutral from existing in to 3 on your new stat
Live into 4 on your new stat
a link between Live and 1 on your new stat
And the black wire on 4 to 2 in your new stat
  • Thanks
Reactions: CBW
Same new thermostat but different old one. Please tell me where wires need to go if you don’t mind. Many thanks
found info on different thread guys. So happy to have heating again!!!!
  • Thanks
Reactions: CBW
Just as an FYI, it’s sometimes better to start a new thread, a reason being is, not everyone reads how old a thread is.
Hi I’m having a problem with my ability to fit the same thermostat. My old thermostat only has 3 wires one of which is an earth. I would start a new thread but I can’t find how to.
This is my old thermostat
This is my new one. How do I wire this one up? Many many thanks in advance
Not sure on that one, as you have no neutral ( if you try and look at wiring or remove old stat ) it may be hidden.
Also starting a new thread ;)
Thanks for the quick reply. I see now and can start a new thread cheers. I’ll pull the old stat off tomorrow and have a look. So much for a five minute job like I told the wife.
Hi , i also have bought a moes wifi thermo, here is my two together, the existing one on top has 4 wires, L and N, which is easy , the bottom two are the one i cannot figure out, I put the brown in L1(1) and the blue in N1 (2), but the boiler wont switch on when i turn the temp up ??. I spun them round and the digital lights on boiler wont turn on , so i guess thats not the right way .....iv saw someone say to branch 1 and 4 ??. is this what i need to do ??, any help would be appreciated ..Thanks
I would but im new to this , and dont know how to ...sorry
Select sub-forum or where you would like to post question, eg plumbing and heating, then there’s should be an orange tab with the words “post new thread”.
