SMPS
DP
10 Dec 2003
Glasgow
Any of you repair pcbs and switch mode power supplies using oscilloscope and other means?
I use different tools everytime, whatever meter comes in front of me I use it.
Multimeter is the mainstay for voltage measurements but how do you check the waveforms
Do you use isolating transformer?
Oscilloscope. Mostly used for checking IC drive signals (in my case)
Always. (Well, most of the times yes. ) The isolation transformer is there to protect you just as much as your scope. It doesn't make working on mains voltage equipment entirely safe, but it does help significantly.
  • Thanks
Reactions: DP
What test leads do you use
I am new to SMPS. Understand the concept, aware of dangers.
Have been faultfinding for some 50 years. Electronic electrical, mechanical, gas boilers etc
Beware, if you are testing your SMPS using an isolation transformer and a scope - when you connect up the probe ground on a traditional scope, you will lose isolation - the circuit won't be floating anymore, as the scope references to earth.
There are some interesting scope meters appearing on Amazon etc. some for less than £100 (one is on my Christmas list!). Being battery powered, you wouldn't lose isolation.
Personally, I haven't used an isolation transformer for troubleshooting, but most of the problems I've found, could be discovered with the circuit dead - i.e. the usual suspects: caps, resistors, diodes, MOSFETs, etc.
  • Thanks
Reactions: DP
Yeah that why I mentioned that my £7 multimeter normally finds the fault.
Don't forget to answer back on the stereo thread ;)
  • Thanks
Reactions: DP
I've got a KeySight diff probe/amp which calls itself "high voltage" but it's not all that high, 100V common mode iirc. Some are rather low. I've used it for some inverters & motor drivers and some high speed serial comms where it reduces the common mode noise problem. It's around here - somewhere, haven't seen it for years.
You should be able to use differential mode on a scope with two normal single ended probes - no need to be concerned with the common mode voltage range, as long as the signal doesn't exceed the general input voltage range.
It's not really needed if you have a handheld/battery type scope though. My Fluke Scopemeter was a few quid but often one of these <£40 ones off ebay would be fine for little stuff. Remarkable for what you can get now for the price of a tank of fuel. Well, £100 - £120.
To date have done repairs where cap checks showed faulty components.
Am aware about earth connection of scope and applying the scope to SMPS where input and output are isolated. For this have differential probes
Have been reading up about different component functions etc
