no (not unless the situation requires it, conduit is for mechanical protection, although if it is to be buried in the wall conduit helps, but you can also use capping)
The cable is running (inside the wall) just above the skirting board, and then vertically up to where the new socket box will be (about 6 inches up from the skirting board, like all the other sockets). So I guess it is in the safety zone.
That being the case, it looks like I can just go ahead and plaster it in!
Am I OK as regards not breaching any regulations? I am not a qualified electrician, but the wiring part of this job is the easy bit!
There is no safe zone running a few inches above the skirting!
Basically safe zones are Horzontally and vertically in line with electricial accessories, and a 150mm 'margin' in corners and along the top of the wall (but not along the base!)
