When wiring a polished metal double socket onto a plastic plasterboard gang,do you have to earth the face plate as you would when fitting to a metal gang?
chrislisawright said:Thanks!
Just wondered why on a metel gang there is a piece of earthing cable connecting the face plate to the gang and on a plastis gang there isn't?
FredFlintstone said:chrislisawright said:Thanks!
Do metal back boxes have to connected to the face plate by way of sleeved earth cable? Only reason I ask is because the face plate attaches to the back box by means of metal screws onto two metal lugs, one of which is fixed.
No so long as one lug is static you do not have to install the fly lead to back box. Personally I always do.
A gang is a group of people, the word is usually used to describe a group of people set upon destroying a bus shelter or about to rob a shop.chrislisawright said:Just wondered why on a metel gang there is a piece of earthing cable connecting the face plate to the gang and on a plastis gang there isn't?
This isn't WHY we use twin and earth. We could use flex, with the same results as twin and earth. Are you saying if we didn't earth face plates, we could just use twin cable and no earths? Because your post seems to suggest that if we didn't have to earth faceplates, we wouldn't need to use earth cables at all.Chri5 said:All face plates are earthed, metal or not, hence why one uses twin and earth
Crafty said:This isn't WHY we use twin and earth. We could use flex, with the same results as twin and earth. Are you saying if we didn't earth face plates, we could just use twin cable and no earths? Because your post seems to suggest that if we didn't have to earth faceplates, we wouldn't need to use earth cables at all.Chri5 said:All face plates are earthed, metal or not, hence why one uses twin and earth
