Socket Outlets in Skirting Board
23 Mar 2008
Devon
Hi
I am new to this forum lark so please treat me gently!!
Although apprenticed as an electrician many many years ago i am not up to date with current regs
My house is Edwardian and as i am finding there is a mixture of different generations of wiring which will need updating
Most of the rooms have socket outlets flush mounted into the large skirting boards. Ring main feeds come up from the suspended floor directly below each socket behind the skirting.
Ideally i would like to keep this arrangement but update wiring and sockets as required.
Any advice gratefully recieved
Sockets that low down are a Bad Idea™, as they can get kicked, whacked by vacuum cleaners, and with moulded plugs the flex may end up being bent at too sharp an angle.
553-01-06
Are you aware of Part P?
However, if you have really high skirting boards, the plug insertion problem might not exist
Thanks for replies so far
Understand the dangers of being kicked or damaged by cleaners etc however they are well clear of the floor so there is no problem with severeley bent plug cables.
Well if they and any plugs are not at mechanical risk you're free to leave them at their current height, or move them up the wall - your choice.
