Hi, wonder if you all can help. I took our kitchen sockets off the wall for redecorating and when putting this socket back on I noticed a green and yellow wire loose. Should this be connected into the same terminal as the other yellow and green wire?
Final question, the screw in this socket is just turning and turning because the brass metal bit has has come away from the blue plastic bit (my fault for trying to use a drill to get the screw in). Is there anything I can do to fix this?
Thanks v much.
Thanks v much.
