Soil pipe collar?
8 Feb 2004
Wolverhampton
If there such a thing as a soil pipe collar that will seal where the pipe goes through a polycarbonate sheet.
I am building a carport at the moment and will be sheeting the roof next week and will have to cut around the soli pipe. Obviously will need to seal around the pipe and don mind paing for a collar if available.
Thanks :D
I have a soil pipe coming up through a felt roof. The collar is a simple plastic cone that I solvent welded onto the pipe just above the roof. The clever bit is the upturned ring of lead underneath which I formed out of lead sheet then fixed onto the felt with hot bitumen and flashing tape.
You need something similar but, in your case, there might be a ready made part that you can solvent weld onto the roof. :idea: :idea: :idea:
I fit quite a few epdm roofs, one of the fittings they do for pipe work, might suit your job.
Its a rubber pipe sleeve with flange, can be cut to allow for pipes from 50mm to about 150mm.
It will slide on same as the roof slate, use the primer and glue to fix down.
If you google Firestone epdm you should be able to find it.
For polycarb use a flashband type. Star cut the hole for pipe, slide it over then wrap a collar around it, use a heat gun. Or google Dektite.
