If you can possibly wait the manufacturers will flood this market in the summer, they all recognise that at present it is dormant.
This concept looks interesting to me, one could conceive one's own diy version quite cheaply I recon. Discuss?
http://www.solartwin.com/easy_to_plumb_in.htm[/QUOTE]
i can't quite see how that will work.
Looks like to me that the DHW flows through a solar panel and if this is so how come the DHW cold fill tank is lower than the panel.
The Combi that i know od that will accept pre heated DHW from solar is a boiler called Wolf TGB 40 as i have fit one this way.
It had a Ariston unvented indirect cyclinder with the cold mains running through it and the heating coil from the solar panels then the hot outlet from the cylinder went to the cold inlet to the combi. Apparntly the Wolf TGB 40 will raise the temp by just a couple of degrees if need be or just let the water flow throught the boiler.According to the Rep who passed us this job on. We have had no comebacks from it so must bve working fine. Before we fit this Wolf boiler it was running through a Vaillant VCW Sine 18 and that managed well for a few years too.
I'm not sure if all combi boilers will cope with pre heated water. I suppose the combi will need a NTC on the cold inlet to sense the water which quite a few combis have these days. Others have them on the outlet or just on the Primary water.
