Used a solder ring for the first time... have only used end feed and compression before. Had to make a join where I didn't think I would fit the solder round the back so thought I'd try the solder ring. One side made a nice little ring, in fact it was so easy I probably wouldn't have bothered ever learning to make end feed joins if I had known how easy it was ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Or so I thought at first, because on the other side, no solder ring appeared! I kept the torch on it for another minute directed at that side, but the pipes started going red and there was still no solder ring so I gave it in.
Since I'm not going to be able to put water in this pipe for quite a while yet, when I do, do you think it's going to leak?
P.S. The end which had no solder ring appear was old pipe, it was quite stiff to push the connector onto, a fair bit stiffer than the new tube, maybe that has something to do with it?
