About 23 months ago I had my system power flushed and sealed,as none of my radiators were getting warm.
My boiler is a Baxi back boiler and I live in a Park Home, with a Calor Gas supply.
One of my radiators, with a pipe that is taken into the open air, is often cold and takes a very long time to heat at all. This has been like this since it was fitted. Before that I had no radiator in that position.
My conservatory radiator went cold a couple of months ago, then three weeks ago the bedroom one started to go cold, or only be luke warm. Now it is cold and so are the pipes too and from it.
Three radiators, closest to the boiler, are hot, one so hot that I can't touch it for long. This radiator is connected directly tothe pump andboiler, as isthe cold bedroom one. All others are on spurs.
At one time the bathroom radiator was cold at the top, but now it is reasonably hot. A couple of days ago I bled the radiators and got air from two of them, but no water when the air stopped.
Today I tried to unscrew the cap of the pump to check if it is working, but can see nothing. However, some water leaked out. The pump has no bleed screws.
Can anyone give advice? I have very litle time to work on this and myhusband can't do anything with water.
