That's right. Just make sure you can switch it off quick, either at the roomstat, the boiler itself, or the programmer, if it makes a noiseSo to be clear you want me to shut off all the radiator valves then fire up the boiler ?
Moved into this house 3 years ago and its always taken about 3 hrs to get the house upto temperature, I found that the pump was connected to the return
pipe so had that changed with a new pump and fitted to the flow side of the system but that has not improve things, not sure if 12 years with the pump on the return has done any damage to the boiler ? The boiler has been serviced.
I've had a quote to remove the very old system water tank ect and convert to a combi system, They want to fit a Glowworm 35Kw boiler with shock arrestor,scale reducer,mag filer and install Hive controls, chemically flush system for £4746.
I can opt for a Vaillant for an extra £395+vat, If the gas supply needs updating thats an additional £580+vat, the house is a 4 bed detached with 14 rads two showers no bath.
Is it worth paying the extra for the Vaillant ?
I should have added - make sure the HW cylinder stat is satisfied, or preferably, close the manual valve.So to be clear you want me to shut off all the radiator valves then fire up the boiler ?
OK, that seems to rule out my theory! Back to square one.Shut all the rads fired up the boiler it ran for maybe a minute then F22 dry error.
I suppose you've tried increasing the pump speed and perhaps its mode of operation? Are your rads adequately sized for the boiler output? If they're too small it would give your symptoms.Only valves I have are these. Think I'll have to wait until winter and see how the system performs.
You will have to update us, did you get a new boiler? did you open the by-pass ? has anything changed ?Any particular reason a boiler would run for an hour or so and then turn off while the thermostat is still calling for heat ?
