Hi.
I'm a fairly competent DIY'er moving a rad from one side of a first floor bedroom to the othe over a distance of 3.5metres.
Joists run in direction of new pipework so no need to lift floorboards if I use speedfit flexible pipework.
However pipework will only be resting on ceiling of room below; i.e. not clipped if I dont lift the floorboards.
Will it be okay like this or will it try and pull itself from the speedfit elbows I'll be using as the lengths tend to try and curl back up when I have cut them?
Cheers
Cheers
