Whoever installed the CHeating, ran a Spur off from the Landing socket, & put onto this spur two FCUs in the airing cupboard, 1 for the CHeating (3 Amp fuse, & 1 for the Immersion Heater (13 Amp fuse).
I just wanted to check if this is Safe & ok how it is or if I should run a new piece of 2.5mm T+E from the CCU to put the CHeating & Immersion Heater FCUs on, & what size MCB would it go on a 16 Amp or 20 Amp And what side of a split-load board would it go on
(P.S. And if a new circuit is the case, I will use the old spur cable to add a double socket in the main bedroom, as the airing cupboard is in the main bedroom.)
