Stair Angle
21 Jun 2006
Cambridgeshire
Can anyone give me a steer? I'm looking at a potential renovation project where the biggest problem I can see is the treacherously steep stair. My question is will the local BCO make me change them to meet regulations or can I leave them alone? Am I right in thinking the acceptable angle is around 40degrees. Think the ones in question are around 52 degrees.
Thanks in advance.
I think that depends on the age of the house. For example I've now done a couple of like for like replacements on terrace houses where the the going on the original staircase wouldn't meet legislation. BCO didn't bat an eyelid. I think the issues arise when you are putting in new or making substantive changes. Their main cincern was that the structure of the stairs was up to scratch, hence a requirement to provide a cross-sectional drawing of the stairs (although not of the winders at the bottom)
Scrit
Thanks for that,
Presumably, the only thing I can do to reduce this steep angle is to replace with an 'L' shape stairs, say three steps up, then 90 degree turn up the rest. Is this sort of thing available 'off the peg' or would it have to be custom made? Ball park figure for something like this?
starting the stairs earlier is a good solution
but as noeseall says you have to watch the headroom
by starting the stairs earlier you will need to open the stairwell proportionately back
by the time you get to the base off the original stairs your going to be approaching 1 mtr higher
and considering the original need to fit a very steep staircase probably means major structural work with major loss of precious space above and around the base off the stairs :cry:
As BA says. Like for like is always the easiest option. If you do go for a staicase with a winder at the bottom they are not off the shelf as every one is different, so you should expect the price to be greater. They also tend to be a 3 man job to install because you probably won't get them through the door or window in one piece, they come in as a winder section, and upper section and "bits". Assembling them in an old, non-square building can be a faff especially if they are over a lower staircae (e.g. 1st floor landing to attic)
Scrit
