Hi All,
I recently had my boiler serviced and since then two of the radiators are cold when the central heating is switched on. Both of the radiators have no facility for a bleeding key but both work very well if I have my solid fuel range on. I thought it might be due to the range pump (btw there is also a main pump for the central heating) so I tried it off and on but no luck.
I am totally baffled by this as the copper pipes taking water to the heaters are hot but the radiators cold, the nearest to the system is a tiny bit warm bottom and top. As I said had I lit a fire in the range they would both be hot. The man who serviced the boiler is now overseas and non-contactable, I wanted to ask him if he had changed any settings.
I do find however that in the morning when the heating has been on for three hours to heat the bath the radiators do heat. Hopefully someone might know the answer and thank you for your assistance.
