Hi I have a Worcester Greenstar condensing boiler and I have a leak coming from the Adjustable Gas Flow Restrictor, Why would this be could i be getting water in from the flue ? thanks in advance guys Cris
Above the gas flow restrictor no 63 is the air gas mixer unit no 29 which is then connected to the fan hence why i thought water was getting in the flue, its very clean water though its a strange one so all help is much appreciated atb cris
Hi Thanks guys I know what I'm not suppose to be doing and I'll be getting a gas safe plumber out but I'm interested at why water should be coming out of there cause I'm not convinced a gas engineer would know either
You have contradicted yourself. You say you know what you're not supposed to be doing, yet you are asking a question about a component you can only view by removing the casing, which you're not supposed to be doing...
