I meant the one that your new stud wall (or single block) is attached to, I viewed your dwg of the existing opening as from the outside. Just re-read your first post, you do say viewed from the inside
That ones 650mm anyway and you're not altering it and it's original so i wouldn't think you'd have a problem with that one. I don't know which one oldun meant but your revised dwg looks ok to give BC an idea of what you're proposing. You could arrange to visit their office for an informal chat before you submit your applications, that way you'll get an idea of what you can do structurally so your initial design can incorporate this. Might save you a few quid on your design fees.
If you don't have an architect/designer lined up and you're considering the yellow pages route, or similar, do your research and get a shortlist of names together. You can then drop these names to BC and whilst they're not allowed to recommend anyone, they will let you know whose work they have the least problems with, if you see what I mean. Same goes for builders.
