Hi Guys
Have removed the old bath now from bathroom and have access to the pipework etc, I have to remove the plasterboard in place at the wet end of the bath.
The wall next to the bath is a stud wall with lath and plaster. What shall i replace the wet end plaster board with?, I will be tiling the walls eventaully.
Also, can I screw new plaster boards over the old lath and plaster? if so what should I use? also what should i use to attach them to the stud partitions.
i need something similar to plasterboard but waterproof, something that can be screwed to the partions and will aloow to be tiled over.
