Our chimney specialist has installed a double-skinned flue for an Aga. This runs right through the house from kitchen ceiling to roof. In the little room above the kitchen I have boxed it in using some shelving fixed at the required 2 inches away from the outside of the flue (see picture). This has left a gap in the floor as the weight-bearing plate is wider than the box.
We will be carpeting this room so I want to level this gap with something tough but flexible enough to resist movement due to heat and floor movements. Then the carpet fitter will glue the gripper rods to it. It also needs to seal the gap to prevent air being sucked in and rising inside the warm box, then out into the attic, which will eventually cause a dark stain as dust collects in the gap.
Any suggestions for a suitable filler/leveller?
