We have just had our back porch demolished and made larger. We are still waiting for the final screed to be put on the floor, but this is effectively a utility room.
What we have now is a U shaped recess, in which I want to place a worktop.
We have 2 plain red-brick walls (left end and back), and an exterior textured house wall (gravel-like texture, really uneven). on the right.
The dimensions of the worktop are to be 1400 x 475 mm, thickness has yet to be decided, as is the height from the floor as we don't have the floor in yet![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My plan is currently to screw 2x1 battens to the wall. 3 screws at 100 mm centres at each end, and 5 screws at 300 mm centres along the back.
Ideally, I would not like a central support at the front, but realistically, I think I might be pushing it. Load wise will be quite a bit. There is a vented tabletop tumble drier with a 3 kg capacity and a tabletop dishwasher, plus other sundries to go on top. A full-size washing machine below.
Firstly, are the battens big enough and screwed in in enough places?
Secondly, if I were to run a horizontal support rail across, near the front, would that be enough?
And if so, what would be the best to minimise thickness? Could I use a hanging rail from a wardrobe for example?
