Hi all,
for the past few months have had a problem with my boiler (Suprima 50).
Original problem was boiler would lockout when ever it felt like it but would reset. It appeared that the 3 way valve was not working have now changed that which has improved the system but boiler still locked out.
Yesterday noticed that the heating side would work for quite a long period but would eventually lock out, once rest heating side switched off the boiler would lock out as soon as the domestic hot water was switched at the programmer. Changed the cylinder stat with no improvement. Frustrated I started to browse the net which led me here, found some good reading ref the problem, have this morning taken my circuit board off found that the reset button had cracked soldering and a few other bad joints. Have now made the joints good. Heating side seems to be working fine now, when a demand is made for the rads the boiler will kick in and fire up doesn't cut out during operation but as soon as the domestic hot is asked for boiler cuts out and shows solid red light on panel. Please can anyone help
