hiya and thanks in advance for any help, in my kitchen i have a switch that does nothing! i want it removed, would i be able to just take it off and tape up the wires, and bury it into the wall???
However, if it was an immersion heater you may find it runs from its own fuse/breaker in the consumer unit. trial and error removing fuses or tripping breakers may isolate whether it is a) on its own isolator and b) nothing else is connected to it.
If that's so you may be able to isolate it at both ends - do you have a multimeter?
Is there only one cable running to it? It could also have been underfloor heating (perhaps unlikely) or someone's attempt to control an under-worktop socket for washing machine, dishwasher etc. - in that last case it might be on the main ring.
