- Joined
- 16 Nov 2018
- Messages
- 112
- Reaction score
- 6
- Country
I've been chasing a problem with my Glow-worm hxi system boiler (Hive control, indirect vented cylinder, Y plan) for a while now and would appreciate some ideas please.
Problem : When there is demand for HW and/or CH, the pump runs and the boiler fires and modulates at the preset 75 degrees just fine. But after a while, the boiler stops burning gas. The pump remains running and HW and/or CH are still being called for as indicated by the Hive receiver. The boiler temp on the front panel drops down to 40-50 degrees but still the boiler won't fire again. It continues in this state for quite some time whereupon the boiler will suddenly fire up again and the whole cycle repeats itself. There are never any fault codes on the boiler panel. I can usually prod it back into life by (for example) switching off the HW schedule whereupon the pump stops, immediately starts again and the boiler fires up because the CH is demanding heat. I'm guessing the movement of the 3 port valve somehow prompts it to start burning again.
Nobody so far can fathom what might be wrong. Random parts have been changed (under BG breakdown cover) including boiler PCA, boiler thermocouples, cylinder stat, and the motor (not the entire header) on the 3 port valve (it burned out last night - I was hoping that somwhoe this would fix the problem I am explaining but it hasn't).
Any suggestions will be very gratefully received.
