Hello,
I’ve inherited a (cheapo) Ferm FZB-720 table saw which needs a new blade. The existing blade is 200mm x 16mm with 20 teeth but I’m struggling to find any of these at a reasonable price.
Toolstation do 200mm blades with 30mm bore and a 16mm reduction bush:
https://www.toolstation.com/shop/Po...sd3137/Toolpak+TCT+Circular+Saw+Blades/p63445
Is this suitable?
Or would I be better with a 190mm blade that has a 16mm bore?https://www.toolstation.com/shop/Po...sd3137/Toolpak+TCT+Circular+Saw+Blades/p78148
I’m ripping long lengths on timber 18mm thick if that makes a difference?
Both of these are advertised as “circular saw blades” - are they ok to be used in a table saw?
Thank you
Is this suitable?
Thank you
