TAPS FROM EBAY, TEARS INCLUDED?
21 Mar 2007
Manchester
Thinking of buying some taps from ebay....
Problem is, I was wondering if bath/basin mixers are interchangable. A bit concerned I might be waiting days for a bath to run...
Are flow rates different for bath taps, and can I rely on sellers who sell a tap as suitable for baths or basins?
Cheers for the help!
Bath taps are usually bigger bore (3/4") than basin taps (1/2").
If your water comes from a tank in the loft you want good big waterways. UK taps are often wider internally than Italian or other imports.
Bath taps usually have a 3/4" connection, whilst basin have 1/2". This is important if you have a standard 'gravity fed' hot tap water system and not a combi/un-vented system ;)
To work at their best combis prefer to have all hot tap pipe work in 1/2".
Even with 3/4 bath taps and a combi you should use a 3/4 - 15mm tap connector, so I can't see why not.
As far as i'm aware your flow rate would not change as you will recieve the same water pressure you have always had. The thing i would consider is the length of the neck of the taps. The reason i say this is becuse i brought some new taps a while back and they were about 10 mil short of the connection. it was a right old pain in the arse job having to change the pipes to match the taps.
aren't they great?
JohnD said:
aren't they great?
Nope. I hate braided flexibles, especially with hot supplies, on which they're just a plumbing time-bomb.
"Problem is, I was wondering if bath/basin mixers are interchangable."
I wouldn't have thought it possible to fit bath "mixers" to a sink and vice versa?
If by "sink" you mean basin, then it's possible to fit a bath tap as long as the hole is big enough.
It's just that he said "mixers". So apart from the difference from the centres being a bit different, the holes in sink and bath being different, and the existing fittings being different then, I suppose they'll be the same.
Fair point, well made. I didn't read his post properly.
I retract my comment and apologise for my mistake.
